What mah should I be charging a 22.2v 3300mah at and what voltage should I be seeing charged
Align 22.2v 6s charging advice please
I always charge at 1C, so 3.3A in your case. If you parallel charge, double that for two and triple for 3...Originally posted by Novicepilot View PostWhat mah should I be charging a 22.2v 3300mah at and what voltage should I be seeing charged
There should be a C charge rate on the cell somewhere.Trex 700 DFC - Vortexted, TRex 600, OUTRAGE FUSION 50, 500ESP, 450PRO, 130x.
When you set your charger to the Lipo setting it should automatically adjust the charge voltage. Fully charged it will be 4.2 volts per cell.Kasama, Minicopter, Henseleit, JR, Shape, Beam
Proud recipient of 7 EGS!
and a platinum star
