New charger advice
  • New charger advice
    Im after some advice on a new battery charger.
    I have looked around and found out as much info as I could
    I plan to charge no more than 4 x 6s 3000mah lipos for my 500
    so..
    25.2V x 4 x 3A = 302Watts @1C (if I have understood correctly)
    the other charge would be max 6 x 3s 2200mah for my 450
    12.6V x 6 x 2.2A = 166Watts @ 1C
    Assuming I would normally charge at 1C what charger would you recommend?
    I realise I would need to convert a server PSU to run most charger which I am prepared to
    I might add that I do not plan on going any larger than a 500 electric , once I progress to a 600 etc I want to go Nitro for that size
    If your happy to spend the money, Hyperion or Revolectrix/Cellpro. I have both and both are really good. The PL8 from Cellpro will give you a little headroom or you could get away with a PL6. I presume you would be parallel charging? If so Cellpro do an individually fused parallel board. Hyperion EOS 0720i would probably be a good choice too.
    I've not used them but people speak highly of the Bantam and Icharger devices too.
    Hop this helps
    D
      I like the icharger. Speak to or email Chris at ElectriFlyer he is very knowledgeable and helpful.
      iCharger 206B « ElectriFlyer
      I'm a bit doubtful about Cellpro. Be careful with parallel charging, it's not a proper way of charging as lipos are not meant to be voltage charged but current charged as the current varies a lot with changes in voltage. Putting lipos in parallel means you are assuming they are all identical which is never true. Make sure you only charge well within the battery spec and keep a check on each battery by individual charging and internal resistance checking. The icharger will check ir for you. Equalise voltages before connecting the batteries together.
      Blade 130-X, MSR, MSRX
      Phoenix Sim
        I was planning on parallel charging as it will make things easier in my opinion. Thanks for the options available, i didnt really want to spend as much as what the PL6 are but I will have a look at the ichargers from Electriflyer
        Thanks for the info regarding paralell charging as well
          1c is fairly slow. I would make sure you have double that capacity incase you need a fast charge at the field or a quick chance to sneak a flight in. I like parallel charging and do at the field but is always good to do an individual charge now and then to check each pack individually
          In have a pl6 for my 500 and its great. I logged a full charge on each individual pack through the pc software so I can monitor the condition of each pack over time.
          JR XG 7
            New charger advice
            Pl8 and the MPA board just got mine and love it.! Charge 6x 5000 at once.
            TREX 600 pro V-BAR
            TREX 500 V-BAR
            DFC
            BLADE 130x
            DX7
            PHOENIX
              That is a beast.... but a bit more than I wanted to pay, if i planned on going electric on helis bigger than 500 then that seems the one to go with but the biggest cells I will charge are for my 500
                Re: New charger advice
                +1 here for IChargers, got 208 and 3010. Decent psu is a must for parallel charging
                Yan
                XL Protos 380, XL Power Specter 700, Align 700Top Dom, Green & Black Vbar Controls.
                  This:
                  and this:
                  P350 Power Supply « ElectriFlyer
                  Reliable 300W set up for less than £140, this is what I use, although slightly under powered for me now its a brilliant set up and very compact. I can parallel 3 6S 4000mah packs at just a tad under 1C.
                  Matt
                    Bear this in mind though, you WILL soon move on from what your flying now and end up wanting more power!! Better to go big now than have to buy twice.
                    Goblin 500 SK540 jive 100lv
                    HD 500 SK540 jive 80 lv
                    Oxy 3 SK540 minijazz20
                      +1 For iChargers and Chris @ Electriflyer.
                      Personally, I'm using a (250W) iCharger 106b with a 350W power supply.
                      T
                        Vicky has info about chargers in her blog. With any new charger I'd watch it very carefully to begin with. If your cells start off from 3.85V and there's no point in keeping them lower, they will charge in about 35 mins at 1C. You don't gain much from the last part of charging and it is better for your cells if you end the charge early. On the icharger there is a fast charge option which stops earlier. If you can charge at the field you'll probably be able to charge for at least 15mins for all batteries except the first. I tend to get the bulk of charging done at home so that the field batteries don't get so drained. Lead acid batteries tend to drop a lot of volts at more than 5 amps and the capacity drops a lot. People then get generators. Other people spend most of their time talking rather than flying and for them field charging isn't a problem. Your batteries should be around 3.80V per cell after a flight or more than 3.6V during flying.
                        I managed to get some old batteries from disabled vehicles from a local shop. I use two 17AH deep charge batteries that happily give 5 amps each.
                        Phoenix Sim
                          Thanks for the advice on chargers- I went with the 306b (which I arrived today) in the end just incase I did decide to go larger than a 500 electric. Chris from Electriflyer was very helpful and I would highly reccommend him.
                          I plan on building my own PSU from 2 server PSU's which are on the way
                            Good choice just what I run, gone a little smaller on the psu's so I can case them up for field charging.
                            Oxy4+, tgy servos, hw60a, spirit fbl on 6s 🤓
                            sigpic - Team pilot
                              Make sure no mains bits can be touched by pets or kids. Best if cases can be earthed, needs track cuts usually. One 12V psu will do to begin with though.
                              Phoenix Sim
