Ripmax Pro Peak PSU
  • Ripmax Pro Peak PSU
    Hi all,
    I currently have a ripmax pro peak PSU and a turnigy 6S charger which is adequate for my current needs. Eventually, I will convert my fusion to a 600 12S FBL setup so will acquire a used cellpro when the time comes. Will the pro peak PSU have enough juice to charge a 12S Lipo at 1C?
    Off the top of my head it is 20A 12V which is 240W.
    Thanks,
    Harry
    Harry
    Powered by Futaba 18SZ
    10s 350w 10xp 600w, so pretty much maxed out doing 2x 6s 5000 @1c
    Santander Factory Team
    Proud wearer of 5 x EGS
      I thought 12S machines only used 3000-4000mAh packs though? Or am I wrong on that? lol
      Harry
        Think most people are using 5000 packs on their 12S setups, I know I am so that I get a reasonable flight time, but this is on a X7 and Rave, the 600 class will use the lower capacity packs.
        The PSU you have will be maxed charging either at 1C, I've got these, the top one is running a voltz charger the bottom I use on my Fusion 712B. I can do 1C on the voltz @ 10A and 0.9C on the bottom with both channels charging.
        http://www.fast-lad.co.uk/store/revo...a-p-13533.html
        http://www.fast-lad.co.uk/store/robb...a-p-13888.html
          If its the same psu as I had 12v(in reality 13.8ish v) 20 amp, dual out put ,you will be able to charge at 1 c, I used to charge two 6s 5000 (packs (turnigy) on a cell pro 10s and a bantam bc 6/10, it used to pull about 17 amp but strangely when I put a pl8 on it only pulls about 13/14 amp
          jeff
          outrage velocity 50 fbl ,v-bar
          logo 600 3d
          mobile bar-b-q
          a few planks and a big overdraft
            I have the more basic model mate, this one:
            Pro Peak Power supply
            Harry
