New Cellpro MPX Charge board on the way
  • New Cellpro MPX Charge board on the way
    Hi Guys just found this
    MPA - Multi-Port Safe Parallel Adapter for XH Compatible Battery Packs, Bare Wire for Power
    just come with bare wires so you can add your own connection part from that its the same as the other board
    not sure when its out but soon i hope
    That's better than having to deal with crappy Deans.
    Henseleit TDR V-Bar x2
    SAB Goblin 700 V-Bar
    T-Rex 700e DFC V-Bar
    Synergy N7 V-Bar OS105 HZ-R
    Synergy E7se V-Bar
    Synergy N5c FBL V-Bar
    Gaui NX7 V-Bar YS91 Tareq SRX
    T-Rex 550 E FBL V-Bar
    Gaui NX4 V-Bar
      Yep sure is. Just had to make 4 deans to EC5 adaptor cables which was a real pain, especially as I am not very good at soldering. Took me 3 hours!!
        Now soldering this will be a real pain. They could just make a version with EC5.
        I am quite happy with MPA/deans, made deans -> EC5 connectors and all works great. My small lipos use deans anyway.
        Michal
          They would come out with a diffent type after I made all my leads up
          That's about right
          Wonder if there will be a Tp style balance board
          As a lot of my packs have Tp valence plugs
            That's about right
            As a lot of my packs have Tp balance plugs
