Electrickery question
  • Electrickery question
    Slightly baffled by the Fusion charger blurb stating it to be 120 W d/c power, but only 90W a/c. Not being too lecky versed I wonder how this comes about. Anyone ?
    Trex 450 SEV2.
    Have a look here, a great site.
    https://sites.google.com/site/tjingu...e-for-charging
      Looked. Lost ! Maths fine, the rest gibberish. Ho hum.
      Trex 450 SEV2.
        Originally posted by CPN
        This is only my opinion and may be totally incorrect....
        Might be right as well for all I know. Still don't get it though.
        Trex 450 SEV2.
          If it has a an a/c plug on it i.e. its own transformer then it can output 90w max but if you have it powered by a seperate 12v supply you can go up to 120w. I think i'm right but not sure, I know some chargers can output more watts using a 15v supply instead of a 12v I'm sure some one can tell you if I'm right????
            What are you charging?
            For example if you are charging a 3s 2200mah at 1c....
            2.2amps x 12.6volts is drawing 27.72 watts add 10% for loss in efficiency from 12vdc and 240vac so 30 watts approx
            Don't draw over 90w on ac and you're good.
            It may be down to the extra heat generated from the ac-dc conversion, that they rate it down for AC
            Just a trusty rusty Raptor E550 these days
              The limiting factor is the dc driven charger. Think of two units. A basic chargers fed from a dc source, and in front of it an optional ac power supply to provide a dc source. To give the max output you will need to put in enough current at enough volts to achieve this. Efficiency of chargers varies and they work in much the same way as a switching BEC. (A dc voltage is switched on and off to produce ac at high frequency. It is then passed through a transformer to produce the low voltage. By using high frequency the design gets cheaper with smaller transformers and capacitors required. The design is more complicated, but the complicated stuff is put into a chip)To get 120 Watts out you need to put about 140 Watts in. Watts is power and is exacly the same as horse power that was used to rate cars. If you use an ac power supply, you will only get 120 Watts out if you put 140Watts in. Perhaps they fitted a 120 Watts power supply? It isn't a mystery and you don't need to understand anything about electricity, just economics and marketing.
              Blade 130-X, MSR, MSRX
              Phoenix Sim
                I would say it's as pDidd said, that on AC it's the AC transformer that's only rated at 90W, either electrically or because of heat output, but when you're running off a DC source then you won't be using the AC input so can run at 120W
                  That's what I said.
                  Phoenix Sim
                    Okay I get it now. It's because it bloody does and that's it ! Ho hum. My brain hurts.
                    Trex 450 SEV2.
