I've always calculated the percentage used from a battery by the mAh's I put back in.
So if I charge a 2200mAh battery and it takes 1,540mAh to put it back to 100%, that would mean it was 70% discharged leaving 30%/660mAh remaining.
A mate said that wasn't a true measure of the percentage remaining and I should use a battery checker, so I bought one. Well, if his reads 45%, mine will read 60% and to confuse things even further the new PL8 will say 35%
Should I be measuring voltage and not mAh's?
Please tell me the most accurate way to check the remaining percentage left in my batteries!
Chris.
Chris.
