When you put your batterys on to charge from a car, do you run the engine as you charge? Should you? Or should you not?
I know a car battery sits about 14v at idle so dont want to mess my charger up. At the same time I Dont want to be unable to start the car after charging a battery!
I want to charge optipower 6s 3000mah.
