i've been looking at this PSU and noted that it has adjustable outputs :
Volts : 5 - 15V
Amps : 0 - 40A
is there a set/optimum voltage to use to charge our packs with or is this set voltage dependant on the pack, e.g., 11.1V pack compared to a 22.2V pack
when would i adjust the amps on the PSU ? would i calculate what amps i require to charge my packs, e.g. 6 x 3000mAh at 1C would be 18amps and then set that
does anyone have the PSU and recommend it ?
Volts : 5 - 15V
Amps : 0 - 40A
