new power supply
  • new power supply
    hi people
    has anyone got or no anything about this power supply from the quick guys?
    Robbe UK 1000 Watt 12-30V Power Supply H1000W
    thinking about getting one to run my Hyperion duo charger what do you think or do you know of anything better? (not a psu unit though) needs to be 24v to get the most out my charger
    that PSU is not enough for your charger assuming you have the 500w per channel hyperion. you will ideally need 1400w to get full power from the charger reliably.
    i have no experience with that PSU though sorry.
    i use server PSU's to get 1600w 24v on my powerlab....works like a charm and change out of 50.
      This is what we use with Shaun's Hyperion Duo:
      Rapid Electronics - Electrical & Power > Power Supplies > Bench PSUs
      A bit cheaper than the Robbe one, and works perfectly
      Proud Sponsor/Pitman/Servant/Slave to Bart101s fleet of Outrage and Avant helicopters
      Bart101 suffers from a medical condition called "Compulsive Inpulsive HeliAddict"
      sigpic X3
        will be charging no bigger them 3300 mah lipos on it so maxing it out will not be an issue, only other wish is for it to be portable, hence the wish to avoid two psu units as i think they are not really that portable
