Which PSU??
  • Which PSU??
    For this charger Hyperion EOS 0610i Duo?
    I want to be able to charge 2 x 5000mah 6s packs on at least 1c so as long as it can do that, happy days
    for two packs you'll need at least a 300 W supply with a higher voltage than 12 V (like 13.8 V, preferably higher).
      Where is a good place to buy such a thing??
      I see ones that are 13.8v but they dont say a watt rating just 20a for example
        Model Shop Leeds - Specialists in radio controlled models
        Can only see a 12v one.
        x 3
          12V @ 20A = 240W but as most put out 13.8v (even if 12v is stated) then
          13.8V @20A = 276W
          Now, if you want to charge a 5000 6S pack at 5C ............
          Steve H
            Pro-Peak Power Supply 13.8V 20A - OIP2000 - ModelmaniacsOnline.Co.Uk
            Would that do the job??
              That will be borderline TBH.
              6S packs charge to 25V and at 5A equals 25*5= 125W thats just for one battery at 1C. You need to double that for batteries in parrallel so 250W.
              Now that is without losses!
              factor in the PSU losses as well as the charger losses and you will easily need something in excess of 300W.
              So @ 13.8V you will need something around 22 Amps.
              Some have used PC Psus and converted those. All you need is to connect the green and black wires on the AT connector and the PSU will switch on.
              Its a cheap way of getting a hefty PSU for the job.
              Ade.
                Cheers Ade but I cant do any leccy mods to anything but if that will do the job ok then thats all good as at home I only slow charge the packs anyway so no huge rush to get them done.
                  Isnt an ATX PSU only 12v though?
                  x 3
                    Ade.
                    Also if you use this routr you need to place a load on the 5V line to stabilise the 12V rail. Currently I have a 20W car bulb attached to mine which does the job.
                    Without the bulb fitted my 12V rail reads approx 10.5V. My cellpro 4S will operate at this voltage but the charge rate is limited to 2A on a 3S pack.
                    With the bulb in place the 12V rail is up at about 11.97V and my cellpro will give out the full 4A.
                    It is a very easy mod to do and is definately a viable alternative
                    Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
                      Here you go twinkle
                      Aurorra Ltd - specialists in electric propulsion systems supplying Lipos, Chargers, Brushless Motors, deans connectors, ESC's and testing equipment we believe in...
                      Henseleit TDR V-Bar x2
                      SAB Goblin 700 V-Bar
                      T-Rex 700e DFC V-Bar
                      Synergy N7 V-Bar OS105 HZ-R
                      Synergy E7se V-Bar
                      Synergy N5c FBL V-Bar
                      Gaui NX7 V-Bar YS91 Tareq SRX
                      T-Rex 550 E FBL V-Bar
                      Gaui NX4 V-Bar
                        Can someone put a link or 2 on here to some PSU's that will work out the box and do the job please, if you got any at all
                        edit: just see yours Rob
                          Lowest prices for Fusion 600W Adjustable Power Supply : Brentford Radio Control Centre
                          Alan
                          Blade mCX
                          Blade mSR
                          Trex 450 Sport S\Combo, with Hitec5065mg servos
                          Trex 550E Flybar S\Combo
                          PhoenixRC
                          DX7
                            Mine came from Maplins, but its not on their site now. Its just like the Aurorra one, and has been faultless.
                            Synergy E7se V-Bar
                            Gaui NX4 V-Bar
                              So that 600w with the Duo charger, what rate will that be able to charge 2 x 6s 5000 packs?
                              2c or there abouts?
