Hi, Hope this is OK on here but I think you RC guys here will be able to help better and talk in a language i understand better than the Bike forum I use. Anyway,
I have an electric bike, had it for about 8 years and is well used but good. It is powered by 3 off, heavy SLA batteries. These are connected in series to give the required 36v, 12A. The batteries are shot and I am exploring the idea of using LIPOS to both save weight and for experimentation purposes before I build a more radical kit based bike.
Lipo batteries are used in many modern e-bikes but are generally viewed as potentially dangerous and other technologies are often prefered.
I am proposing to purchase 4 off, 5s, 5000mah packs from HK. By wiring each pair in series to give 10s and then those pairs in parallel I would have 36v (nom) and 10ah capacity. With 15c rated cells the peak power requirement of approx 18amps draw should be easily achieved and life in terms of recharging cycles should be good.
For a start are the above statements true?
With RC models, battery management is generally taken care of by the ESC but on e-bikes a battery management system (BMS) is fitted within the battery compartment. This is where I am starting to struggle.
The BMS really does two things - it shuts down the motor when the voltage gets too low and on better systems also manages balancing of cells during the charging process. Manufacturers of cheaper e-bikes claim that "Lipos don't go out of balance" and leave out that facility!
I don't want to spend well over a hundred quid on batteries and mess it up so am asking for your advice!
Without opening up the battery case every time I charge the cells, pulling them out individually and balance charging on my RC charger what is the alternative? I could charge with a readily available "intelligent" 36v Lipo charger that are sold for these type of applications but I wouldn't be balancing. Should I plan for a mixture of the two methods even though it would be a lot of messing about?
What low voltage warning devices are available? Something simple such as a warning buzzer?
Any suggestions with wiring schematics etc would be gratefully received!
Thanks, Dave
Thanks, Dave
