Loong Max Tipple 6s 4000 vs 4500
  • Loong Max Tipple 6s 4000 vs 4500
    I ordered a 4500mAH 6s from Giant Cod, but received a 4000mAH 6s instead.
    The 4000 only just fits under the canopy of my 500esp, so I am unsure as to whether or not a 4500 would have been a good idea anyway.
    Does any body have both, and can tell me if there is a size difference between the 2? Or if they have a 500esp and a 4500, whether or not it fits under the standard canopy?
    Life's a bitch and then you fly!!
    T-Rex 450 Pro, GP780, R6106hfc
    T-Rex 500 esp, Quark, R6106hfc - For Sale
    T-Rex 600 LE, Metal Quark, OS55, A395, R6008hs, Multigov Pro
    T-Rex 700LE FBL, OS91H, CGY750, BLS451s, BLS251
    SRIMOK 90N cyber conversion, YS91SRS, CGY750, Radix, BLS352s, BLS251
    8FG - Now with 14 channels!
    I would have thought that 4000 or the 4500mah 6s pack would be too heavy on the trex 500 and would make it quite nose heavy?
    When I had my align 500 I was running mine on 6s 2600 packs. Even my protos 500 is running these packs, and have gone as high as the 3000 packs.. but feel any bigger would just throw the whole c of g out.
    ANdy - CDMFC
    Align 550 Beast X
    Proud owner of 3 x E.G.S.
      Most people use 3000 maximum on a 500, that will probably be quite nose heavy I'd have thought. 4500 I can't see fitting at all!
        The 4000 actually fits beautifully!
        The CoG is perfect if the battery is fitted as far back as it can go.
        I am gad they didn't send the 4500 then
