Yes-RC 867 charger problem :(
  • Yes-RC 867 charger problem :(
    Hey guys, I'm hoping you can help!
    I have a Yes-RC i-peak 867 charger and have been using it for probably around a year now but recently the LED screen has been playing up and the right side has become blocky and unreadable.... I was wondering if any of you have encountered similar problems with any of your chargers or other bits of kit and can suggest anything to try and get the screen working again!
    PS it seems to charge my lipos fine but I can't see the mah values etc so makes for interesting times
    Many thanks! I really hope you can help!
    link to product in question-
    http://www.yes-rc.com/pdf/Yes_I-Peak867_UK_web.pdf
    Regards, Ross
    Raptor 50 V2 - Quick UK shizz
    T-Rex 500 ESP that looks like it's been Tango'd!
    Re: Yes-RC 867 charger problem
    Anyone have any words of wisdom??
    Regards, Ross
      Any suggestions for a good solid charger to replace it?? Up to at least 6 cell at a decent cost
      Regards, Ross
        ross i cant say i even ever herd of that charger , so i cant help , but if your looking for a good charger that will look after you 6s packs it has to be a cellpro 10s or if you looking for a really good charger Hyperion are bringing out a supposed to be great one some time soon ish ,i hope , their is a charger from hobbyking i be leave is good to can do two 6s at a time i think but at low c charge very cheap . you could pm crissb on it or do a search here in the forum
        thin to remember if your going to be in to electric helis for the long hall then a good height out put charger is the way to go with the new 5c charge rate packs about now , can cut down on charging time .
        look here http://www.aurorra.info/aurv2/catalog.php?cat=6&count=0
        you can give mike a call very helpful , anything u need to no & if you do say hi from me here in Ireland
        jim
