Pro Peak
  • Pro Peak
    My Pro Peak Prodigy works on the flight box battery, but when I plug it into the lighter socket on the car I get "Battery input voltage error" any ideas guys.
    Tried switching polarity and turning car on.
    Mack
    Thought I was finished with the crashing thing!!
    1]Bad connection somewhere, or
    2]your car battery is overcharged due to a faulty regulator(probably not, cos you would be blowing fuses/bulbs and god knows what electronic doohickies), or
    3] your battery is undercharged(probably not as you would also notice the effects of this when starting),or
    3] fag ash :lol:
    probably first thing though, does the lighter actualy glow red?
      1] No
      2] No
      3] No
      4] Yes
      Tried on 2 different cars,(one which was being used to charge) still the same.
      Mack
        Hi Mack
        Get the same thing - mine's a Renault - it only shows this when charging Li- Po's .
        Hav'nt really got a clue why.!!
        Sorry
        Will watch this space for enlightenment.
        Dave
          AAh, I havnt tried it on lipos in the van, but its working on nicd/nimh
          Mack were you charging lipos?
          ill try a lipo in the van and let you know
            Charging NiCd only. Havn't tried anything else.
            Mack
              Check voltage of car battery and field cell, is the car battery higher?
              Maybe your prodigys have a flakey cut off point, it might have been badly set at factory
              triple check connections, including the contact between plug and socket, (not all plugs/sockets are created equal, I have had problems with some
                Sorry none of the above. As stated before I have checked and tried on different cars.
                Mack
                  well, you have the answer then..its F**ked
