RC1 lipo
  • RC1 lipo
    Hi a few of us have been using these lipos http://www.hobbyking.com/hobbyking/s...arehouse_.html
    and for ten pound each you get 6 to 8 minutes flight time just wondered if anyone else had used them and wanted to know if anyone knew the maximum charge rate for these cells.
    Thanks.
    P.S you need to sign into your HK account to see them
      Capacity(mAh) 2650
      Config (s) 6
      Discharge (c) 0
      Weight (g) 435
      Max Charge Rate (C) 0
      Length-A(mm) 140
      Height-B(mm) 43
      Width-C(mm) 35
      That's from Hobbykings webpage !!,, and seeing as no warranty is given,best stick to 1C charge rate or 2.2A ..
      Sab Goblin 570
      Sab Goblin 500
      500E Pro dfc
      450 Pro dfc
      Blade 300X
      DX9
