Hi all,
What's the cheapest/easiest way to parallel charge small (~500mAh) 3S Lipos with a JST connector, using a PL8? I have the fused MPA board - should I just get some EC5 to JST connectors?
Or do I pull the red/black banana leads out of the PL8 and use this (http://electriflyer.co.uk/4mm-to-jst-mini-x-6-parallel/) leaving the balance lead of the MPA board plugged in for the LiPo balance plugs?
Thanks!
Thanks!
