charging 3s batteries?
  • charging 3s batteries?
    The last time I used 3s batteries I used to charge them individually, on a cellpro 4s gold through the balance plug only
    I now have a pl8 with mpa board, can I just parallel charge them the same way through the pl8? Or will I also have to use the discharge cables?
    SPY750 CLASSIFIED in build
    TBS DISCOVERY enroute
    Trex 450 pro in bits
    Both I think Vin, the same as u would your 6s 😄
    Ronnie
    Goblin 700 - HC3sx- Konny Pyro 700-52 - konny 120hv - bls 251 - bls 451s
    Goblin 570 -demon 3sx - konny 100lv - xnova motor - Bk 7001s -BK 7005
    Boggy combat plank - wot 4 - EFX - ECt ECt lol
    FUTABA T14SG
    PMHC - A128FREEFLY - Thurrock model flying club - TTI
    GUINNESS WORLD RECORD PILOT 2012 & 2013
    GRASS ROOTS 1st PLACE, FEB 2013 ( FOR BEST CRASH LOL )
      I was hoping it wouldnt be that way, a bunch of soldering to be done
        Yes, I just tested this, it is possible to charge through balance connectors only with PL8 and MPA.
        What I did:
        1. Plug in Lipo's to balance connectors.
        2. Select charge current (remember the current is 100% going through balance taps so limit to 4-5A)
        3. Select "No" to parallel charge.
        4. Start as per normal single lipo charge.
          Thanks st200ol, that would make things easier
            If you use the balance connectors you need to remember that they are small wires that are meant for voltage sensing. If the battery voltages differ by too much they can end up melting when one battery tries to charge another. Small resistors can be fitted in series which you then short out once the volts have equalised.
            Blade 130-X, MSR, MSRX
            Phoenix Sim
              The OP is using the MPA board, so no need, it has auto resetting poly-fuses between all balance taps that limit the current flow if voltages are mismatched.
                The fuses are a safety feature. You still need to keep the voltages as close as possible to avoid high charging currents.
                Phoenix Sim
