Battery charging nimh
  • Battery charging nimh
    Hi All,
    i have an imax b6 charger and I'm new to the rc world. I need to charge my glow starter it's 1800 sub-c nimh 1.2v battery. What voltage settings should I be using and for how long?
    sam
    I don't know your charger but you will probably just set it at NihM and a charge rate of 200 mah. Best rate is 10% of capacity.
    The charger will stop when it's done. From completely flat about 9 hours but in practice it will be way less than that.
    Check your charger has auto-voltage setting but I bet it does. It will auto calculate the pack voltage
    Happy Landings.
    David
    Raptor 50. OS50
    Mcpx
    Blade 130x
    Goblin 500
      That's a really old NiMH sub c have been 3300mah for donkies!
      If you have a wall charger the yes 10% of capacity for 15hrs will charge it.
      However if its a peak detecting fast charger than you need to charge it faster or it will probably "false peak" and stop early.
      Sub c will happily charge at 1c just be aware of your cabling
      Sent from my Nexus 7 using Tapatalk
      www.accurc.com
      adrian@accurc.com
      This is an apple free zone
