Ok to use again?
Probably a good idea to run through a few charge discharge cycles somewhere safe, like were it won't matter if it smokes or goes up. See if it keeps it charge for a few weeks.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Blade 130-X, MSR, MSRX
Phoenix Sim
I have just charged it up with no probs...int res is at normal figures,it tacho'd by the strap and not the carbon frames.
I will leave it on the patio tonight lolT- rex 600n V-bar
I am probably a little complacent, or maybe a tight git? But I have had several damaged more than that of yours and am still flying with them. No problems during the last 2 years. I even have one that fried 1 cell of a 6s pack. I fly it as a 5 cell and have had around 40 GOOD flights with it as a warm up pack and it comes down hardly warm.Been there and done that, but never stop learning.
I think it will be fine,it's held up over night,the heli never went in hard,the lipo came unplugged doing tic tocs at 0 pitch so just fluttered to the deck but landed on its nose
I think it's more likely to die during charging than flying. The danger is that there's a break or a weakness in the membrane that separates the two halves. This stops the lipo charging above a certain voltage. (It's been converted into a zener diode). If you charge at high current or parallel charge there could be enough current across the break to start a chain reaction. You can't trust lipos anyway, this one just needs trusting less.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Phoenix Sim
Im happy with the single bullets Pete,i am normally careful with them and when i feel a bad connection i sort it but last night i had just been sat on the mower for an hour and rushed to get another flight in as the light was fading....more haste,less speedOriginally posted by discoferret View PostGet those bullets changed over to ec5. Don had the exact same thing happen to him recently bullets came apart in mid air.
Re: Ok to use again?
Fair enough :-)Originally posted by Nick B View PostIm happy with the single bullets Pete,i am normally careful with them and when i feel a bad connection i sort it but last night i had just been sat on the mower for an hour and rushed to get another flight in as the light was fading....more haste,less speed
