Servo choice for 6hv?
  • Servo choice for 6hv?
    Well I picked up my new 6hv today. :biggrin:
    I was originally planning on Putting it together relatively cheap i.e.align ds610 for the cyclic, ds620 or ds650 for the tail and a beast x but now I have it in my hands I think I want to stick better servos in it along with a mini vbar. So looking for some suggestions for servos? I do like the idea of the mks ds760 for the tail or maybe a bls251, not sure for the cyclics though
    Goblin 700
    Got 610's in mine which do the job fine.
    Simon
    Trex 700N & E
    x 2
      Yep looking at servo specs on fast lad, there aren't many servos that can match the speed and torque of the 610s for the money.
      Goblin 700
        Totally agree, maybe on the 90 sized stuff you could warrant better servo's but then I see so many models at my field being given a beating with 610's fitted and can't remember anyone having a problem. Didn't have much of a budget to get my 6HV in the air so waited till some popped up secondhand. Never seems to be many days where someone is swapping them out of a combo or splitting an airframe.
        Simon
        Trex 700N & E
        x 2
          Did you get stung for any duty/VAT in the end Andy?
          Ian
          Knight 3D
          Velocity 50
            [QUOTE=chugga-bug;724627]Did you get stung for any duty/VAT in the end Andy?[/QUOTE]
            Well I ended up canceling my order from hk and picking it up form westonuk. I just didn't want any surprises because it would mean it would cost more than buying it from here. I guess buying it from a uk supplier can only be a good thing too if I require any support in the future
            Goblin 700
              Cyclics
              Outrage 9180
              MKS DS760 (James Moon uses these)
              MKS HBL950
              tail
              Outrage 9188
              MKS BL990
              But loads still sticking with 610's for value/performance
              Eddie
              Velocity 90 FBL BeastX V3
              Trex 600 LE FBL BeastX V3
              Trex 500 EFL Pro BeastX V3
              Fusion 50 FBL
              VBar
              All powered by a DX8
                All about futaba bls 255hv, superb servo!!! Every heli i own is getting a set!!!
                  I used BLS252 on cyclic when I had mine, very precise and center perfect every time (this is where the difference comes in) but cant remember what tail servo. Prob a 254 or something but there is a good choice of tail servos about atm, 254, 9188, 990 etc etc
                    Would the mks 1210 be suffiecient for cyclic?
                    Long live the flybar.
                      on my 6HV i have Mcgregor DS8915 on cyclic, and a DS8900 on the tail
                      GaZzA
                      Compass 6HV FBL Telemetery Beast x
                      T-Rex 500 FBL Beast x
                      mSR
                      Simstick
                      DX8
                        [QUOTE=cupracing;724657]Well I ended up canceling my order from hk and picking it up form westonuk. I just didn't want any surprises because it would mean it would cost more than buying it from here. I guess buying it from a uk supplier can only be a good thing too if I require any support in the future[/QUOTE]
                        Might be a bit more expensive fromWeston UK,but great service and VERY helpful on the phone..:cheers2:
