As a few of you know i have a newish Compass Atom,had afew flights stock setup,then decided to convert to fbl.
Bought a s/h head and a Beastxv2 this afto.
Its got Align 510's on cyclic and 9254 on tail.
After all nite reading the manual etc think i've got it sussed.
2 problems: one of the Align servos has play on the bearing,is it a common problem with these servos,my other 2 seem fine.
Plus i'm getting about 8 degrees pitch in setup 'j' just as the blue light comes on,balls on the swash are the 'nearer' ones ie without the washer,i could move the servo horn balls towards the servo screw but would make the horns-swash linkage a biggish angle,so is colour red ok or should i move the horn ball?
thanks..
thanks..
