2 styles of starter shaft
  • 2 styles of starter shaft
    Hi again,
    There now seems to be 2 versions of the starter shaft. I thinh I must have the earlier version [B]KN-02-0316 [/B]which is now quite worn so want to replace it with a new one. I was in Mr Models today and I think he only has the new version([B]KN-02-0317[/B]). Are there any other items I would neeed to switch to the new version , ie bearing or starter socket etc.
    Also why did they change the shaft??
    Simon:)
    OLD Trex 450
    Knight 50 Sport : OS hyper . Sab 620 . Gy401/9254 . 3x 3152 . revloc 10 . Carbsmart . Align 2 in 1 reg 2 x 2600 fromeco li-ion batteries
    you've lost me on this one:confused: :confused: :confused:
    www.lincsheli.com
      [QUOTE=simowill;37695]Hi again,
      Simon:)[/QUOTE]
      Yea theres a bloody lot actually.
      My Knight 50 pro was the old version and what a bloody pain the $%^%^
      You need starter shaft and Bearing block (unless you can get the old ones out)/ Clutch hub bearing or new clutch Hub I think is better choice.
      The new shaft is wider so all bearings in that area must be changed.
      Call Skyline they have all the stuff.
      Mark
      www.uavaerialservices.co.uk
      BNUCs - Operations certified
      CAA - Permit for Aerial Work
        clutch bell, pinion, pinion bearing, start shaft bearing hex adapter are all different.
        to get the bearings out just warm them ontop of the toaster and the will push out easily. Same with the mainshaft bearings.
        Ade
        www.accurc.com
        adrian@accurc.com
        This is an apple free zone
          Yea thats the lot pain in the ass to get the bearings out but Skyline looked after me. Allowed me to send the bearing block back as I couldn't get the buggers out. and the bearings and did it for me. everything I tryed failed.
          Mark
            [QUOTE=Disc;37728]Yea thats the lot pain in the ass to get the bearings out but Skyline looked after me. Allowed me to send the bearing block back as I couldn't get the buggers out. and the bearings and did it for me. everything I tryed failed.[/QUOTE]
            You didn't go for the technical adjustment tool then?...........the hammer!
            www.lincsheli.com
              [QUOTE]You didn't go for the technical adjustment tool then?...........the hammer![/QUOTE]
              AKA the gentle persuasion device :D
              | 3D Championship
                LMAO
                nothing hit or over abused otherwise skyline may not of been so good
                Mark
                  [B]KN-02-0316[/B]
                  Is the Number for the old style and the new style shaft,
                  The difference apart from the E clip is the shaft is the same dia, not stepped down like the 1st ones.
                  [B]KN-02-0317[/B]
                  Is the 3d version part number but is the same as the sport one as far as I can see.
                  At the moment the parts manuals, for the 3d pinion bearing is shown wrong but listed the right size.
                  And yes as listed the larger shaft means everything from the clutch bell up needs replacing.
                  Although skyline had the older style one the other day.
                  www.evorc.com
                  Beam E4 Specialists with a complete stock.
                  Synergy, Rave, Align, ElyQ We stock kits, spares and SE upgrades.
                  See web for many other top brands.
                  Feel free to call just for a chat.
                    I have an older style one on order from skyline, it's been about two weeks now. I hope the other day is longer ago than that!!
                    I looked at changing it all over and I suppose in the future I will have to. Spoke to skyline yesterday and they said they were hoping to get them in that day. I am expecting to get a little envelope on my mat tomorrow!
                    It has made me a bit upset, my pro is about a year old and already bits are obsolete. Pain in the a**e...
                    Note to self, Must Fly more
                    My other money pit www.tornadouk.com
                    my club [url]www.cdrcc.co.uk[url]
                      [QUOTE=phil485;37749]I have an older style one on order from skyline, it's been about two weeks now. I hope the other day is longer ago than that!!
                      It has made me a bit upset, my pro is about a year old and already bits are obsolete. Pain in the a**e...[/QUOTE]
                      Yea they didn't have any old ones due in when I got mine so I swaped over to the new one but at least it is done.
                      Mark
                        Thanks for the replies chaps. Looks like if I can't find the old style shaft I'll have to spend yet more money!!!!
                        Simon:(
                        OLD Trex 450
                          [QUOTE=simowill;38407]Thanks for the replies chaps. Looks like if I can't find the old style shaft I'll have to spend yet more money!!!!
                          Simon:([/QUOTE]
                          Yea well they told me no more old style but double check what they send you
                          as I got the wrong part at one point and the clutch hub won't just take the bearing been altered if I rember correctly requires the whole thing.
                          Mark
                            martin at mr models has them i believe
                            Ade
                            www.accurc.com
                            adrian@accurc.com
                              Cheers Ade,
                              I went there yesterday, but found out he's closed on Wednesday....Doh!!
                              Simon
                              OLD Trex 450
