About the state that Blitzy was allowed to get into in the barn.
Since it really is a high end heli of it's era it is cleaning up quite well.. the bearings are all japanese quality and have hardly suffered beyond a little cosmetic surface corrosion that scrubs off.
After cleaning those bearings I've coated the surfaces in silicone grease then polished that off: less is more..you don't want dust sticking.
The caphead bolts are mostly nasty and I'm working through still cleaning up parts and refitting with s/s where there's no concerns about shear forces on the bolts.
For the grub screws I don't like s/s - it's too soft at the cheap A2 grade one buys on ebay so they get cleaned or replaced like for like.
The engine is a mess externally..the backplate screws look like 4 tiny dollops of runny dog-poo although the bearing and crank doesn't look very corroded at all but while it's out the engine will get a complete overhaul.
I have a few problems there.. this setup has a cline regulator and it really doesn't want to come off the fuel nipple and if I force it any more it'll get damaged. They are hard to source now and I do have some spare innards but not a spare case. That means that I can't get at the needle seat flats to unbolt it so it'll have to get back-flushed and flushed through the needle area only. I plan on changing all these corroded engine bolts with s/s and the bearings to s/s - which is what i put in there 2 years ago so they've done pretty darned well since it has a fuel magnet and never gets drained!
I've been working at this about for a few hours each evening for about a week now and really only done the tail/boom/mainshaft and head.. engine came out tonight. If the new bearing ever get delivered with this weather then I'll do the engine next but it'll be a pig to get the clutch off. If no bearings then more on the airframe:
The manual clearly states not to disassemble the autohub but I figure I have no choice but try. It may end up with a call to Neil if I c0ck-up or find it impossible. And pull and check the shafts to the tail pinion gear. Beyond that it's mostly scrub the alloy parts clean and new s/s bolts.. but I need a new drive belt (the reason i had to auto and why it got neglected) and a new skid (the result of the auto) but I've been waiting for the dismantling to see if any other parts were needed. So far not.
Taking it apart as a clean heli would be fast..the time is in assessing each part, scrubbing it and measuring up for new bolts and some I've had to grind down to size from my stocks. Ckeaning up the fancy washers is the biggest pain..just stain from the caphead rust but those things are 0.48 each and at least 80 or so of them to be brass brushed.
This is teaching me not to neglect a heli again..
and a platinum star
