Had me 50 out today 1st time ever and when its hovering it shakes ??????? Is okay on ground spooling up but as get it in air just starts shaking , + needs 3/4 stick to hover ?? Would training legs afect it as had these on
Raptor 50 shakes
Assuming the main blades are balanced it's probably the training legs causing the shakes, there tends to be a resonant frequency that clauses this and changing the head speed will stop the shaking.
Did the head speed seem very high or low, when it was hovering?
This brings the next question you mention it hovers at 3/4 stick do you have any idea how much pitch you have at this 3/4 position? I have no idea what pitch curve you are running so difficult to know which way to go.
Paul.Align 700N
Align 600N
Align 550L
Goblin 380
Lynx Oxy2
2 Dumb Thumbs!
Heli was set up by seasoned pro so it should be ok set up wise will balance blades and try with training legs off see what that does , thanks for your helpRaptor 50 , raptor 30 , eflite blade 500 3d, blade 450 3d, spektrum dx7s,
hitec eclipse pro 7 tx with optima receivers
Blade 130x with lynx upgrades
raptor 90 under construction
Pitch curve is 1, 31% 2 inh, 3,50% 4inh 5,100%
heli head speed didnt sound low but then again is 1st time ive played with it so wouldnt really know for sureRaptor 50 , raptor 30 , eflite blade 500 3d, blade 450 3d, spektrum dx7s,
