Servo clash
  • Servo clash
    Trying to set up my MT. I have all the electrics working in the right directions but I am finding that the rear of the three swash plate servos is clashing with the frame when the swash plate gets close to the bottom. At the moment there is no spacer between my hitec 65mg and the frame were they screw onto the frame.
    Should I add something there to move the servo towards the swashplate and hence allow the servo arm to miss the frame?
    Let me know if that not clear and I will add a picture of the problem.
    Ed
    had the same problem, just pack the servo forward with some washers.
    the linkage to the swash plate needs to be parallel with the main shaft. i also packed the other too servos so that the linkages were parallel with the main shaft looking from the side of the Helli .
