Hello all.
I have recently built a mini titan V1 which I really love. However, I am suffereing from a lot of vibration and shaking on spool up and spool down. Also, I can see a lot of vibration through the skids while hovering. I have tried all sorts of things to get rid of this. I have replaced the main and feathering shafts, new dampers, new stiff carbon blades correctly tightened with equal tension (perfectly balanced and tracking true), new main rotor hub, all linkages checked for correct length using digital calipers etc and still it suffers from this problem.
I have therefore decided to go for a all metal head to try and get rid of this once and for all and wondered which one would suit best.
I've seen replacement units made by Sonix and Kasama and wondered if anybody had any experience with these as I am not sure which one to go for.
Or indeed, is there another which would suit even better.
Any comments or suggestions would be greatly appreciated.
Carl
Carl
