Considering Going fbl on mini t
  • Considering Going fbl on mini t
    Hi guys
    Would a trex 450 pro fbl head fit on a mini titan shaft etc without any problems and also would i require any electric upgrades such as esc to cope with beastx?
    current spec: hs 55 on cyclic, ds 420 on tail, standard motor and 45a esc, aslo had have scorp 45a esc new in box.
    Ciaran
    CiaranMal1
    Mini Titan E325 FOR SALE
    Blade 120SR FOR SALE
    Trex 450pro Savoux SH-0257MGS, DS 420, FBL Beastx.
    Trex 550e COMING SOON PHOENIX SIM
    DX7
    The 450 head will fit the Mini T shaft no problem. As a suggestion, also fit some of these, they make make a big difference.
    The HS55 is a budget servo and whilst they will work, there are (as always) better options out there. If it is possible to upgrade to HS5065 digitals then it will allow much better performance from the Beast.
    Hope it helps.
    TRex 500 ESP VBar
    Flybarless is more
      Thanks I also have found on the site and hf a conversion fbl using stock mini titan parts. Would you recommend it? What fbl head have you on your mini t?
      Ciaran
      CiaranMal1
      DX7
        I have RJX conversion on mine, works great.
        Also, as per your OP, mine runs a standard motor and a scorpion 45A ESC, the DS420 is OK but I upgraded to a 9257 for a rock solid tail.
        TRex 500 ESP VBar
        Flybarless is more
