Spare Parts
  • Spare Parts
    Looks like spares are a problem... i've tried my 10 nearest model shops (that takes me nearly 100 miles away) for a link rod set PV0754.
    The rod i'm after is a 1.3mmx7mm stud - used on the mixer arm up on the head!
    Anyone got an alternative part ideas?
    Thunder Tiger sort it out... no good selling models with out the backup
    Regards,
    Matt
    Mini titan with kit ESC & motor, Tornado LiPo 1800mAh, GY401, 2.4GHz Futaba Radio & 3x HS56hb cyclic servo's + Futaba 3154 tail servo + JP LI-PRO PLUS 5 BALANCER CHARGER with 10A PSU
    View My: E325 Blog : Web Site
    PS3 User Name: applematt ¦ Big up AppleMac!
    Have you tried Real Raptors on line?
    Helis:
    Knight50 Pro: OS50H, REVLOCK 10, 401, CURTIS PIPE.
    Raptor 30 V1: (on the wardrobe)
    Trex450V2: Hytec65s's,401 with 9250, Revolution 3s2200 bateries.
    Medivac & Easycopter V2
    http://www.mrmodels.co.uk/
    http://www.dorsetmodelhelicopterclub.co.uk
    Planks:
    Tutor 40 trainer
    Hanger 9 Spitfire: Saito 1.0 4 stroke
    Multiplex Twinstar 2.
      Tried Midlands or revolution. if you cant get from these two shops i would get worried
        Midlands dont have any... i'll try thr others!
        Regards,
        Matt
          I presume you tried Colchester A1 models, i think they stock Mini Titans
            Just ordered from Realraptors... their site didnt say they didnt have any - i'll find out in the next few days i spose!
            Regards,
            Matt
              Pretty sure the trex has a rod set that would have the required length.
              Velocity 50
              Synergy N5
              Fury 55 FBL
              Trex 700
                Why not phone Amerang, the importer on 01903 765496
                  Pity
                  http://www.store.rcheliaddict.co.uk/...9&cat=0&page=1
                  Instock too.
                  Stuart
                    will be spending the next few day's uploading a full line of spares for Synergy & Knight 50 3D, just about to spend £6k with Ripmax and a few £k with others too.
                    Stuart
                      Hi Stuart
                      Are you thinking of stocking Raptor spares ?
                      Regards,
                      Cheers, Lee.
                      Proud recipient of an EGS
                        Hi Lee,
                        Yes, the only 30 in the line up will be the Raptor and supporting parts, possibly the 50 spares too. 50's kits are Compass and Align with supporting spares, then the Synergy for your sweet .90.
                        Stuart
                          If you can't find any mini Titan parts in the U.K. try this SHOP
                          ..: People Fly Airplanes, Pilots Fly Helicopters :..
                          TT mini Titan E325 | GY401 | KONTRONIK Jazz 40-6-18 governor mode | JGF 450TH | G-Force CNC head | RADIX blades | FS 60 Swash | HS81MG Tail | Kong Power 3S1P 2200mAh | mx-12 (35Mhz)
                            Advertising and publicity!! I think you need a little more than 'shop' on the tool bar!!
                            Terry
                            **Trex 450 SE V2
                            **Futaba FF7
                            **Futaba 7c 2.4ghz
                            ARC Ready 2 (trainer)
                              yes, stuart a little more advertising, as its not the first shop that springs to mind....yet
                              All the best
                              Tony.
