My Mini-T
  • #31
    I tried gov mode last night and the esc went into thermal cut-off within 5mins.... the esc was steaming!
    Glad it gave a warning as that could have cost me big time
    I'm using a 3s 1800mah 25c lipo... with the basic motor & esc... lipo was cool, unlike the esc...
    Regards,
    Matt
    Mini titan with kit ESC & motor, Tornado LiPo 1800mAh, GY401, 2.4GHz Futaba Radio & 3x HS56hb cyclic servo's + Futaba 3154 tail servo + JP LI-PRO PLUS 5 BALANCER CHARGER with 10A PSU
    View My: E325 Blog : Web Site
    PS3 User Name: applematt ¦ Big up AppleMac!
    • #32
      Originally posted by applematt View Post
      What pitch curve are you using with the 0-50-70-90-90?
      10 0 10 (or there abouts) in all modes. The T-rex seems to favor a decent headspeed and I like it to 'feel' the same in all flight modes (normal, idle up and hold).
      Cheers, Lee.
      Proud recipient of an EGS
      • #33
        I'm a learner... i doubt i'll be 10-0-10 for a while yet!!!!
        Regards,
        Matt
        • #34
          I went from a fixed pitch ESky Honey Bee to 10 0 10 on my first CP heli and have stayed with it. I learnt on a full pitch heli and I guess I've not known any different.
          I didn't personally find learning with a full pitch range an issue and I haven't had to deal with any stick positional changes as I have got better (albeit very slightly ) if that makes sense.
          Cheers, Lee.
          • #35
            Originally posted by Fixxxer View Post
            The diffrence as far as I see it between governor and just a straight throttle curve is that the govenor attempts to keep the head speed constant no matter what load is put on the blades. With a normal straight pitch curve if the headspeed starts to drop due to a load increase the throttle stays where it is and doesn't try to compensate unlike the governor does so the head speed will not pick back up until the load is decreased.
            Should have been 'with a normal straight throttle curve.....'
            The mini-t does seem to require a good headspeed of at least 2500 IMO and from many other threads i've read on other forums it seems that it runs hot anyway but I've never had issues with ESC temps, just the motor for a while. As I have said the wooden blades a not very good. If you want to run woodies incase of a crash then the align ones would be better but you would then need the TT blade spacers.
            Velocity 50
            Synergy N5
            Fury 55 FBL
            Trex 700
