Which FBL Head.
  • Which FBL Head.
    Anyone know which FBL head & links I'd need for my Mini-T
    • Flickr Through My Pictures.
    Hi,
    I don't believe there is a specific FBL head available for the mini-titan but there are a few universal FBL heads out there for 450 sized machines.
    Check out here for 450 sized FBL heads etc: Fast Lad Performance
    Mikado do a Universal 450 sized FBL head: Fast Lad Performance
    Mikado Universal Swash Driver Assembly: Fast Lad Performance
    I believe you could fit these to the Mini-Titan, you may be required to change the balls on the swash etc as the Mini-Titan uses smaller balls and links to most other 450 sized helis.
    Hope this helps!
    Thanks!
    Rossco
    Equipment for Sale:
      I'm using this RJX 450 head on my VBar Mini Titan: Fast Lad Performance
      Change the dampers for these: Fast Lad Performance for a significant increase in performance life
      TRex 500 ESP VBar
      Flybarless is more
        She's now FBL with the Beastx but ended up with bit of a mix & match to get the FBL setup.
        Flown her couple times this eve & she feels real good so weather permitting tomorrow will take her through her 3d punishment.
        List of bits to do the mod:
        Mikado head & wash out.
        Align pro swash plate.
        450 V2 links set
        450 ball/screw kit.
        450 pro link set.
        Temp plate holder' for swash plate just untill I get a carbon fibre one made.
        So now I've Beastx'd 250se, 450pro, & Mini Titan 325se.
