Best motor for mini titan?
  • Best motor for mini titan?
    Hi,
    Today, it seems that the motor in my mini titan has decided to fail, the bearings are shot i reckon. I just wondered what aftermarket motor is best to use in the mini titan, or 450 size heli? Just for general sport flying and stuff.
    Cheers.
    Blade CX2
    Mini Titan
    If it is the bearings and you are happy with the motor cheapest option would be replacing the bearings
    Not sure what the best motor option is for the MT but at a guess best bang for your quid would be something from Scorpion
    Phil
      I have a Scorpion 2221-8 in mine, seems to work very well.
        I too have this motor with a skorpion 55amp esc. it is gooooood!
        JAMIE,
        -Mini Titan e325-
        Sonix cnc head & tail rotor
        GY401 & HDS 577 servo
        HS65mg's
        CY radix blades
        scorpion hk2221-8 motor & 55a esc
        Spektrum DX7-goodbye glitches
          Scorpion -8 is good but if you want mental go with the -6. Got one on my 450 and its so much fun!! Sucks the life out of the lipos though with a max of 4 minutes in idle up!!!
            how many teeth on the pinion are you using?
            SAB Goblin 700, Gaui NX7, Goblin 500, Gaui NX4, Forza450EX - Many others come and gone but all V-Bar-ed!
              I use the 3550kv motor from sportsmoto (you will need the 13 tooth pinion as well) its a good motor for general sport flying and IMO it has more power than the original TT motor, it also runs much cooler.
              http://www.sportsmoto.co.uk/acatalog...ic_Motors.html
              Martin
              Martin
              x2
              Rave 450
              Trex 250se
              DX7se
                Dismantled the motor with a view to replacing the bearings, but they seem fine. But the outer case had 3mm or so of vertical play in it. The grub screw that holds the outer case to the shaft had come loose, letting it all move about. Re assembled it all, but it still seems tight to turn when its hot after a flight.
                Blade CX2
                Mini Titan
                  Not at all happy with this motor, for some reason it tightens right up after couple minutes of use. So have ordered a Scorpion -8. Thanks for all your replies and help guys!
                  Blade CX2
                  Mini Titan
                    Several times now on my motor the pot slips on the shaft & gets hot same time makes a bearing noise so assuming its the same motor you need to loosen the screw on top of the pot slighly lift the pot, put a drop of loctite in the top then just lift pot up & down to spread loctite then secure screw.
                    Mines been fine since.
                    • Flickr Through My Pictures.
