Battery Connectors - Soldering
  • Battery Connectors - Soldering
    Hi
    Can anyone recommend a good soldering iron for attaching the gold connectors to LiPo batteries? Does one require special solder at all?
    I have bought the 3.5mm connectors for my spare batteries and now want to connect them.
    Pity one cany crimp them...
    Duneflyer
    Mini Titan E325;
    Blade 400, Blade CX2 - Xtreme Upgrade;
    Century UK Dolphin CX; Belt CP, Belt CP v2;
    TX DX6i (plus others);Phoenix flight sim; Spares - a lot of them!
    Picooz - quite a few of them & Schweizer 300 (this is where it all started);
    I bought a cheap one from Wilkes which does the job fine. I do recall seeing electric and gas ones on the Fastlads website for a good price. As for solder, i was recommened to get some with contains flux. Dont know much about it, but it does the job just fine for soldering battery connections.
    Rgds
    Aidi
    700N 700E 550E
      I use this one from Maplins. If you time it right, it can be bought on sale... I got mine for £9.99!
      And some solder
      | 3D Championship
        Hi Dune...
        I am in the same boat and have been reading up on it.....alot of people say get the solder that reads 60/40 with flux its a mixture of lead/tin, altho I read that the 'lead' bit is bad for the environment. I got a 40w soldering iron on Ebay supposed to be made for 'Homebase' about a fiver all in!!
        Terry
        **Trex 450 SE V2
        **Futaba FF7
        **Futaba 7c 2.4ghz
        ARC Ready 2 (trainer)
          for soldering on to gold connections, its best to rub the gold plate back to under layer with a needle file to make a good contact patch for the solder to stick to. Solder "floats" on the plating and can be picked off unless this is done.
          A fine diameter 60/40 solder is best for work round a heli's electrics as its all fairly fine work.
          Any soldering iron with a fine / medium tip will be grand. Most start from a fiver up.
          It's all about the size of your chopper...
            And some solder
            Exactly what I have, it does a grand job and I also got for £9.99
            Only thing the tip it comes with is a bit thin so I bought a medium tip.
            I also like 60/40 solder that lead free stuff does not like gold plate.
            T-Rex 500ESP FBL Beastx
            T-Rex 450SE V2
            Futaba 7c 2.4ghz
