Ace RC TG6100M HH Gyro
  • Ace RC TG6100M HH Gyro
    Hi Guys,
    The stated Head Lock Gyro comes as part of the ARTF Mini Titan package.
    Is anyone aware of where I can find a comprehensive Instruction/User Guide for this item? (ie: the adjusting of the onboard pot for Pitch/Expo)?
    The following that I have found is useful, but doesn't help explain how to configure the settings/pot on the top of this unit...
    Quote:
    TG-6100M is the so-call E-CCPM control board, which is combined with heading lock gyro and an E-CCPM mixer, the heading lock gyro helps to control the heli, and the E-CCPM mixer program makes it possible to fly the mini titan E325 with a normal 4-6 channel radio. The normal flying mode and aerobatic mode are established in the program, if you are using a 4-5 channel radio, you can do the normal flying, if you are using 6 channel radio, you can perform advance aerobatic flying as well.
    Cheers in advance.
    - Thunder Tiger Mini Titan (450, e-CCPM)
    - E-Sky Belt CP (450, CCPM)
    - E-Flite Blade CX2 (micro, coaxial).
    - Various Planes and Flying Wings...
    ....I've decided to go with the Thunder Tiger E325 Flybar weights - PV0828 - Flybar Weights E325. Nice clean and simple way of reducing the sensitivity of my Mini Titan without playing around with the electronics (that could easily make things worse!).
    Have been trawling the net trying to find suitable flybar weights that are designed for OTHER Heli's, but now (finally) I've found the real deal - Thunder Tigers own answer, for the E325!
    The Spectrum DX6i plus Rx will be my next upgrade anyway, so I will then have the facility of changing the Expo directly, from the Tx.
    Cheers.
