Hi guys
Hope you all managed to get out and have a fly around this weekend.
I did an hour with my b450 sat
Anyways enough waffle. I I'm trying to set up the tail on my raptor 30. I have mechanically set it up, programmed my quark gyro so far so good. The tail blade v stick & gyro direction is correct.
Down to buisness. I mounted it to a lazy susi in rate mode, when I start to spool up slowly increasing speed. When it's at say a quarter throttle I can hold the tail for a second then the heli wants to spin but if I correct it quick enough, it will hold until it wants to spin the other way. If she does spin it is at a right rate of knots which to be hounest is a bit worrying!
I'm using a Dx6i and the gyro settings are HH 60 and rate 40
The tail blades sit at about 8deg at centre stick and there is plenty of pitch in both directions.
Any suggestions please.
Dave
Dave
