50Titan & 50se
  • 50Titan & 50se
    Hello
    Can anybody help, i have just got a raptor 50se i have noticed that the titan has push and pull controls from the elevator and pitch servo, is this actuly beneficial as they do not go to the suface there controling, it seems a bit half hearted is there a benefit as to my eyes there not true push and pull, also when fitting the servo to the airframe no metion is made for useing the servo rubber mounts just the metal paltes that come with them, and lastly tail mounted servo`s i have the nhp one and the thunder raptor upgrade both have there benefits I'm sure but the nhp one ask you to file a tail gearbox screw and casing not happy with this idea, and thunder tiger uprgrade uses a metal plate and a metal rod, now niether plate from the upgrade is the same, but i traced the plate`s on a piece of paper (over the top of each other linning the mounting holes up were they attach to the pod) where the servo horn sits on both is identicail, so I`ll use the hhp servo plate but does a carbon rod do justice over the metal thunder tiger one...?
    sorry if i sound silly
    Karl
    Raptor 50 se
    O.S. 50 SX-H Ringed Hyper
    NHP Razor pro blades
    Futaba FF9 super
    Futaba 9255 Servo's pitch & collective
    Futaba 3152 Throttle servo
    Futaba 401 Gyro & 9254 Rudder Servo
    & finally
    Not got a clue....!
    :eek:
    wanna AVRO now
