X50 pitch control fork
  • X50 pitch control fork
    Having not built a heli before - sorry if this is a stupid Q
    This relates to the pitch control fork assembly.
    The Slider bushing 'slides' through the pitch control slider, and through both passes the tail rotor shaft. This gives a male thread at the end of the slider bushing ... the drawing shows the next item to be ... "Tail pitch control fork"
    The items along with assembly drawing shown on this pic :
    The hole through the "Tail pitch control fork" (4) has no female thread ... do I just screw it onto the Slider bushing anyway ? .... I assume it is threaded for a reason.
    If it is screwed on is it just until touching the slider bushing (3) ?
    Some people will always find fault - if you find a typo, consider it put there for you.
    yes just screw it on
    Hirobo Turbulence D3
    1/4 scale Vario Bell 47 G3
    1/3 scale Vario R22
    2012 LHC Scale Cup Judge
      Thanks ... one of those things I thought was right but wanted to check before I proceeded - Ta
