well thought if i can flip roll and hover invert with the trex 500 i can do it with the .60, hell yeah that was good didnt push my luck though only put one tank through her.
anyway so that was that then i put the trex 500 up and was tring to do a tick tok and it went rong and i smashed the trex 500
canopy bolts
main blades
main gear
bottom frame
skids
two servo gears
main push rod to fbl head
and maybe the fethering shaft and main shaft??
i blame the shit cheep blades i was using there not as wide as the 3d ones i had before and seam to have no lift its like i have to use all the pitch to get the heli to clime if that makes sence.
anyway bits ordered so up again soon i hope..
i wasnt comfatble with the blades on there tonight i shouldnt of flown the 500.
canopy bolts
main blades
main gear
bottom frame
skids
two servo gears
