Raptor alloy Tail Pitch Slider
  • Raptor alloy Tail Pitch Slider
    Been getting a very nasty glitch on the Raptor 50 SE & on first look I couldnt fathom what it was. There was a bit of play in the main mast due to the top collar not being snug enough against the top bearing but I didnt think this was the cause. I also noticed the tail pitch slider had a fair bit of play in the linkage which I have just tightened up, its an alloy butterfly with brass threaded insert. Now Ive tightened it up the tail is notchy & Im not sure if the bearing is stuffed or I've not got it right & the brass bush is rubbing the bearing. So I loosened the brass bush off again but its still notchy. So I'm confused where this knotchy rubbing is coming from. Could it be the tail belt twisted over & rubbing if it is it's been like this since I got.
    Martin
    Aka RCSlopesurfer
    Hi Martin
    Dont see how! Didnt i part strip it to post it? boom out main shaft out
    and skids off?
    Regards Steve
      Yeh mate you did.
      I meant when I put it back together
      I've found what it is, the two bearings in the plastic housing are both notchy I will pop in to the shop on the way back from flying tommorow & get them replaced. Can you remember if this plastic housing is a standard part Steve?
      It is definately the bearings as the brass shaft is wearing on its outside where it runs in the bearings.
      I guess the metal to metal is what is causing the huge radio glitches Ive been getting.
      Martin
      Martin
      Aka RCSlopesurfer
        Hi Martin
        Bloody memory lol as far as i can remember they are but take them with
        you then you can make sure!
        Regards Steve
          Originally posted by Raptormadsteve View Post
          Hi Martin
          Regards Steve
          No worries mate, it does look the same as on the 30 but I will take them in with me lets hope he has some in stock cause I want to fly her more & more every week
          Martin
          Aka RCSlopesurfer
            Hi Martin
            I'm still morning the loss of that one so dont rub it in lol.
            Steve
              Yeh I can understand that mate after flying it.
              Took a while to get my nerve but its so stable & just asks to be used.
              Martin
              Aka RCSlopesurfer
                No it dont! it begs for it lol... Thats why i sold it was scared to break it "my pride and joy"
                Steve
                  Pete does it justice for me from time to time mate
                  Martin
                  Aka RCSlopesurfer
