I am hoping someone has some advice on my next build issue!
I have a TT50H engine with the standard Titan 50 fan etc. I have assembled it all but the main nut holding the clutch / flywheel assembly just keeps coming loose!
I have tried three times now and each time the engine fires then cuts out and I can see the fan has moved away from the engine casing.
I am tightening this thing as tight as i dare without damaging the threads - I have a piston locking tool and am really putting quite some torque on it with thread lock yet still it keeps coming loose.....
Any words of wisdom - is it worth trying a locking washer under the nut or double nutting it??
Chris
Chris
BEAR
