After not flying my raptor 50 for a while and on going issues with it I finally think I got to the bottom of my engine problems which turned out to be bad fuel, a bad carb and plastic debris in the header tank. So I was flying it around gently doing some smooth backwards 8s and bang the tail went nuts and gave a real nasty kick!
I landed it and and had a closer inspection. The tail belt seemed a bit on the tight side and I think it might of made the 1way stick?? Whilst I took the 1way out to check it I also noticed my clutch rubbing on the bell but also unevenly... I stripped the engine out and it seems the clutch is worn down on the corners but one side slightly differed to the other...
Hopefully those problems are what made the tail kick but any thoughts welcome
