Guys - refitting Moonmanflyer's 91HZ into his airframe (well they are mine now obviously
When fitting the fan to the engine spindle, the manual says to just tighten it by hand and not use a piston lock (I don't have one anyway)
Then to grip the fan with a towel and tighten the lock nut with some threadlock and a wrench.
Is this the perceived wisdom here -
Will that be tight enough fit?
I guess the motor rotation will prevent that lock-nut from coming undone.
Any tips very welcome as I'm treading on virgin snow here
Thanks - Keith
)When fitting the fan to the engine spindle, the manual says to just tighten it by hand and not use a piston lock (I don't have one anyway)
Will that be tight enough fit?I guess the motor rotation will prevent that lock-nut from coming undone.
Thanks - Keith
