620mm Carbon Blades for Titan ?
  • 620mm Carbon Blades for Titan ?
    Does anyone know of a good source for 62cm Carbon Fibre main blades for the Raptor Titan?
    Google has failed to hit any UK suppliers on line
    Cheers.
    M
    Raptor 50v3 Titan, OS50 Hyper, Futaba S3152 Servos, Futaba 401 Gyro, CSM Revlock 10, Futaba T9CP Super TX.
    GT450s Flexwing Microlight G-MASI.
    "For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." Leonardo da Vinci
    https://www.revolutionmodels.co.uk/a...LADES_165.html
    http://www.modelhelicopters.co.uk/ac...lades_Sab.html
    http://www.quickuk.co.uk/acatalog/r_index.htm
    ..or have this lot been black listed?
    Clones are bad
    .... that includes Align ones
      I bought my SAB 620s from Midland helis (modelhelicopters.co.uk) for my Sceadu Evo 50.
      Stunning blades!
      | 3D Championship
        Not Yet, Give em time
        So Whats the collective wisdom on which Main's to go for ?
        M
          What are you going to be doing with the helicopter?
          | 3D Championship
            Er Try Skyline as well
            Mark
            www.uavaerialservices.co.uk
            BNUCs - Operations certified
            CAA - Permit for Aerial Work
              Crashing it mainly
              But between crashes it will be just "normal" sports flying, nothing fancy even when I stop crashing.
              M
                JP Carbon blades will do fine for your style of flying then - and they are only approx £35.
                There are alternatives, but not that I have tried - in that price range.
                I hope that helps.
                | 3D Championship
                  Maybe woodies would be a good idea if your gonna crash a fair bit for a start
                  they are cheaper
                  Gaza07
                  Trex 500esp 6s Beast-X V3
                  Trex 600esp 12s Beast-X V3
                  A few Multi Rotors
                    bbt's are quite a good blade and cheap... wood stick see what i did there to woodies for a while though
                    cheers Lee
                      Hi
                      There are a few makes of 62cm blades around but a lot more chioce in 60cm, I persoanly still run 60cm jobs (Radix)
                      Longer blades will be slightly more stable but the differnce in stablity between makes of blades makes more of a differnce than their length.
                      Your woodies will be fine for now as long as you keep the head speed sensible and glue the roots on.
                      NHP, SAB and BBT make 62cm carbon blades.
                      Every one makes 60cm carbon blades, stick with any of the major brands and you will be fine.
                      Be warned that once you switch to carbon blades you won't want to go back to woddies so this can make learning more expensive as they break just as easy.
                      Bob J
                        Agree with all of the above,woodies are fine and can actually be quite tough,keep within manufacturers recommended headspeed which will always be lower than allowed with carbon
                        JP carbons are very good for the price,so are Sabs and the new Thunder Tiger ones..All of these are at the cheaper end of the Carbon blade market
                          I personally use quite a few of the JP carbon blades, at the moment I have them in 550's, 600's and 710's they are a great blade for the money and aren't that disimilar in looks or performance to the more expensive SAB blades, which I was originally using.
                          Pete.
                          Rise from the ashes with
