gyro suggestions?
  • gyro suggestions?
    I have an x50 nitro flybarred with a gp900 gyro/receiver, cannot power it up, no lights, although worked o.k. in the past? can anyone recommend alternative set-up if I can't get another the same?
    Thanks, Mike.
    Odd that you've got no power on it at all. Has the rest of the heli powered up okay, so receiver and cyclic servos
      Gp900 gyro acts as a receiver with spektrum satellites, the lead to gyro has power but nothing in gyro or satellites.
        So are there leds on on the Rx side of it and is it bound
          No lights and will not bind.
            I'm wondering whether to go for seperate receiver and gyro, just seems expensive!
              Don't know about gyros, you could probably get one on ebay since not so many people use flybar these days (I sold a Spartan a while back).
              You could probably also use a flybarless device... I know Spirit supports flybar mode. Advantage is that you get self-level/rescue and are half-way to switching to flybarless, though it's more expensive going this way.
              I for one prefer using a full receiver to satellites. You've got thicker more reliable cables, and Spektrum satellites are very easy to brown-out because they run off a low voltage. But up to you.
                I've a couple of Align GP750 Gyros sitting in a box in the shed, don't know for sure what state they're in as I've never flown them myself, but they came off 600N flybar models and by all accounts were flying fine when I bought them. If you want them, they're yours.
                Electronics:
                Sims: Realflight / AccuRC
                  On my x50 i have a separate reciever with satellite and a spartan quark brilliant gyro works a treat and so easy to set up i also use them on my other helis
                  set them up once and forget about it. go to spartan website as they are on offer now.
                    Or go to the for sale section on the 1st page there is a page blades various sizes which has been put on by angelos and the quark is on offer for £37 .bargain
                      Csm720 or futaba gy520 if i would ever have a flybarred heli again, not very likely
                      Santander Factory Team
                      Proud wearer of 5 x EGS
                        Yes futaba 520 i also have one on my raptor titan good gyro harder to set up , nowt wrong with flybarred lol!
                          if I recall the old beastx would work fine as a FB gyro and if you convert to FBL then you already have a gyro
                          NB: if I would go back to FB helis I would get the spartan quark
                          | Kraken : Neo | Atom 6HV : Neo | Vbct
                            The self levelling/rescue sounds interesting as I'm not that experienced! have you any more info.? Thanks, Mike.
