Hi,
Have a 50 SE running BBT carbon blades (TT type black/white).
Problem: -
With link rods and double links all set as per manual I get the desired -10 -> +11 pitch. Now turning the head 180deg (I stay on the same side of the heli) and pitching the other blade it is some 2deg out (-). Why?
Swapping blades (checking for warp etc.) still gives the same result!
Why do I need to adjust the link rod as it should be the same!
Flying with the adjusted rod she does seem in track, but she can do wildly out @ 0deg sometimes.
Dampers and feathering shaft are new.
Any ideas as I just can't see why it needs changing, also is it giving me the 0deg tracking problem.
Please!!
M
Problem: -
Please!!
M
