Hi Everybody!
With the impending release of the Synergy N5C i have created this thread for building 'Hints & Tips'. These will be updated and added to with official Hints & Tips and also for member to add their own Hints & Tips.
Tail Output Shaft Positioning:
Screw in 3mm cup point set screws so they are very close to contacting the flat spot on the tail output shaft. Slide the tail output shaft all the way to the left side of the tail box and secure the set screws. Doing this assures you will have the correct 5 degree offset in your tail blades when all tail bell cranks are set to their correct 90 degree position.
** Note ** – You do not need the entire throw range in order for the tail to counter act torque correctly. With the Futaba CGY750 my throws are set to 130% on both sides.
