Another stripped gear!
  • Another stripped gear!
    "ops i did again"
    after a month of using my Redline, i thought i'd give my OS55 ago, so starting from factory settings started to tune the engine. At tank 4, thought had the engine pretty much singing so started off then this god awful noise (initially thought bearing) so landed.
    Stripped heli down, and i've stripped the main gear again.
    N5 grounded for a while again - brasic you see
    oh, and to boot broke the tail boom on my 1 day old mcpx
    Get that backlash set a bit better. I stripped one main gear while I had mine, and that was down to a way too loose gear mesh. Set it with a pure of paper at the tightest spot and all will be good. Mine was for about 80 flights til I sold it
