Anyone use a Header tank?
  • Anyone use a Header tank?
    Bit of a dilema at the mo, whether to use a fuel magnet or header tank on the N5 - currently using a standard clunk.
    The more natural answer is to use a fuel magnet, but does anyone run a header tank?
    If so how did you mount one?
    Cheers in advance
    Daz.
    No header on mine, just a fuel magnet which works a treat and is so far lasting very well
      I have a fuel magnet on my N9 which seems to work ok but have a header tank with a Quick UK mounting kit fitted to my 700 which I have to say gives me more confidence than the fuel magnet.
      Its just one of those things, as Jamie says his magnet works fine and has lasted ok as has mine (always keep the fuel tank full). The downside of a header tank is it's something else to brake off in a crash.
      Sean,
      Logo 700 Xxtreme
      SAB Gobbler 700
      SAB Gobby 500
      T-Rex 700, Now FuBarred (Lol)
      T-Rex 700E, 12s Fun
      T-Rex 250 FBL, Less parts to break,
      DJi 450 FPV Flamewheel
      1 Very understanding Wife
        I've currently got an OS Bubbleless clunk in mine as my OMI Fuel Magnet foam perished on the field one weekend and i had no replacement foams so this was the only thing to hand and i've just left it in as it seems to be working well.
        Never had an issue with the OMI Fuel Magnet, i use these in everything. They just take a little more care when used in a application where they are exposed to exhaust gases. I usually make sure the magnet is always wet with fuel.
        Thanks!
        Rossco
        Equipment for Sale:
          I dont think this is generally a specific N5 question.. more on what you prefer as the same really applies to all heli's.
          If you decide the Header tank.. you can do what some people do and just stick it to the main tank.. but I brought the QuK header tank fitting kit http://www.fast-lad.co.uk/store/h5511_quick_header_tank_mounting_silver-p-4139.html and dremelled a new hole in the frame to mount it.
          If you decide the Magnet route and If your not wanting to go the OMI route how about the new Lynx magnets http://www.fast-lad.co.uk/store/lynx_heli_inovations_moas_fuel_tank_clunk_lx0090-p-11386.html?
          Eddie
          Velocity 90 FBL BeastX V3
          Trex 600 LE FBL BeastX V3
          Trex 500 EFL Pro BeastX V3
          Fusion 50 FBL
          VBar
          All powered by a DX8
            I just picked up a raptor tank and fitting kit for my TZ Frenzy, although its no N5 its the first time I have used a header tank im about to fit it now and I hope that it cures the leaning out of the engine while flying.
            will test on sunday
            Mike
            www.RC-Scotland.com
            TZ Frenzy .53 Red Line
            T-Rex 600 .52 ASP
            T-Rex 600 .80 ASP 4ST
              any chance of a picture of the header mounted to your N5 ?
              Mark
              www.uavaerialservices.co.uk
              BNUCs - Operations certified
              CAA - Permit for Aerial Work
                I have a "bubbleless" clunk in the main tank of my 600, and also use a header. i like the "comfort factor" of the header - the fuel in which I seldom actually use, as I land when the main tank is empty.
                Mike
                TRex 600NSP, OS55, MicroBeast
                TRex 500ESP
                Futaba 14SG Optifuel 20%
                  Sorry Mark, I havn't got a N5. Thats why I said in my original post its user choice and not Heli specific!
                  Having a look at the N5.. I've done some pics to see if it helps you guys.. from my original post, I said I dremelled new hole to mount the header using the QuK fitting kit instead of "sticking" the header to the main tank.
                  In Pic 1 & 2 Heres where I drilled a new hole in my T600 and used the mounting kit and a pic of a N5 marked with where it could go, if you fancied doing the same. In Pic 3, The hole could dremelled underneath the main tank as shown in the red circle and you have seperate spacers to get clearance you want
                  Eddie
                  Fusion 50 FBL
                  VBar
                    OS Bubble less clunk in my 700's
                    Was using magnets but lack of stock made me try these.
                    Wonderful product that doesn't perish.
                      I have one of the OS bubbleless clunk's on my N5, one in the main and i have a header tank too.
                      Have the header tank fitted into the lower bearing block rear hole using the Quick UK header tank stand off's, found this brought it inline with the carb the best.
                      Works a treat
                      Mat W
                      Midland Helicopters
                      Mikado Slogo 600SE "Low Head Speed"
                      Avant Aurora 90 FBL
                      MSH Mini Protos 450 FBL
                      Taya Imperio
                      Kalt Space Baron
                        Many thanks for the pictures guys, certainly seems that a header tank is doable, I think I may give this ago.
                          Works a treat
                          Mat W
                          Thanks explains a lot will order the QuickUK header tank stand off set
                          Requires a call to Midlands me thinks
                          Just wish the website was better
                          Mark
