Mixer arm angles
  • Mixer arm angles
    As this is unclear in the manual I wonder if anyone can clear this up for me?
    Should the mixer arms be level and flat at 0 pitch like the pitch compensator OR should they be at 90 degrees to the long link going up to them like on an Avant Aurora head?
    The n5 manual is pretty vague in this respect compared to the Aurora one.
    90 degrees I believe otherwise you will not get an even throw positive/negative
    Nick
    Henseleit TDR 2011 VBar 5.2, Avant Aurora, 700N BeastX, 500 BeastX
    Member of Byley MFC & South Cheshire HeliAddicts (www.southcheshire.rcheliaddict.co.uk)
      So 90 to the long link then? Makes sense but wanted to be sure
        correct
        Nick
          Yep, same as Aurora
            Thought as much but seeing as everything else I own is now FBL I had forgotten how to set up this old school techology :P
              There is a lot to be said for FBL...most common thing is no faffing as long as it's not 3G of course as the tail gyro is still under going beta testing
              Phil
