I think everybody has covered most of the points, good and not so good, on the N5 so I won't repeat, but here are a couple of mods/ideas that maybe of use to peoples. 1st one I posted in another thread but repeated here.
1) Firstly If you want to speed the cyclics up (without reducing the stability by moving the balls on the bell/hiller mixing arms on the grips) just replace the two short balls on the the inner ring of the swashplate that you connect the long pitch links too with the longer balls (same P/N as the 3 used on the outer ring of the swash)
This will give you more direct cyclic input into the blade without reducing stability!! Win Win.
The swashplate is IMO quite a low ratio design and easily allows this little mod to work. Being low ratio will make it good for flybarless conversions too, by putting the short balls back on!
BTW, I have actually done this mod (see pic below) and like it. An easy fix for those that want that extra bit of cyclic but not wanting to compromise the stability of the heli!!
2) If like me you are a fan of the CSM 720 but wondering how best to mount it. Here is how I did it (see pictures to save me describing it). Two carbon plates and the plastic mount is a Compass Gyro plate > http://www.evorc.com/product.php/97/...-mount-plastic
I found the N9 rear gyro mount didn't fit the frames to well so used this method. This method also keeps the gyro below the canopy line so looks cleaner IMO.
Obviously need to keep an eye on the gyro mounting pad due to fuel ingress, but a small price to pay IMO.
I used the same method on my N9s and it works very well. In fact both the N9 and now the N5 seem to be the best models I have mounted my 720s in, in terms of gyro performance/vibration levels
Abit of work I know but worth it to get the 720 mounted well!!
