Stole this from Matt's post over at allmyrc.com.
Hopefully Climbout will be offering the deal over here.
On my machines I opted for the metal main blade grips and tail blade grips. The only other thing that could be upgraded are the main shaft bearing blocks (I like the plastic ones, they are quite a bit lighter) and the G10 frames. We are offering an introductory upgrade package for 100 dollars that includes metal main blade grips, metal tail blade grips, and metal main shaft bearing blocks. Its a pretty sweet deal for what you are getting. Carbon frames will be offered shortly after the initial release.
If you are an aggressive 3D pilot I would highly recommend the metal blade grips!
Hope that helps!
Matt
Hope that helps!
Matt
